- 8 Feb 2008
- UK
Thanks to the guidance of the users of this forum I learnt that the most important thing to look for in getting the right PSU is the amp rating on the +12volt rails.
My question, is there any difference in a two PSUs that suplpy the same amps on the +12v rails but are rated with different wattages
For examples, this Tagan 900W:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-TG&groupid=701&catid=123&subcat=1100
Its spec. confirms 64A on the +12v rails, now they also do a 800W version of that PSU which has exactly the same modular connectivity and the same 64A on the +12v rails but delivers a different wattage. Are these basically the same PSU but by getting the 800W you can supply the ~??A you require but at reduced cost.
Thanks
Danny
Thanks
Danny
Think of all the wasted power if every computer PSU out their had no PFC
