PSU and case cooling
26 Dec 2009
London
So i've heard two arguments regarding the placement of the PSU.
  1. Fan facing downward so it gets cool air from outside the case (if you have a vent at the bottom of the case ofcourse)
  2. Fan facing upward so the PSU sucks hot air from the case and blows it out.
Which is true?
I'm considering a Define XL, anyone know the best way to set up the cooling?
Both are true. The first option is better for airflow in the case, as sucking air downwards pulls air to the area below the GPU, instead of being pulled over the GPU and through the CPU cooler.
i think he means both options when the psu is mounted at the bottom of the case. some cases let you mount it either way up at the bottom.
People on this forum need better grammar. :rolleyes:
Almost all cases with a bottom mounted PSU allow you to mount it either way up. Both the arguments he gave are true, but the first scenario is best, because it keeps better airflow in the case.
Who is you referring to?
Yes meant when the PSU is mounted at the bottom which way round is best.
So the Define XL is BIG and so when tested by several people like bit-tech, they found the case isn't very good at cooling, why since they used the stock cooling, i.e only 1 fan at the very front bringing in air.
If i buy a decent number of fans say another 2 to make it total of 3 blowing air in, would that be good enough? They also say the 180MM fan at an angle on the roof of the case does a very bad job as an exhaust surely this is as not much air is being brought into the case for it to blow any out, right?
Anyways to go for the define xl or not?
hot air go's up, so in my eyes if the fan is facing up it would help heat up your case? by removing the low laying cold air?
I have my PSU fan facing down as instructed by the case maker.
