PSU and fan questions
18 Feb 2007
PSU and case fan questions
Ok so I'm buying a new PSU most likely Corsair HX 620W or the 520W.
What I want to know is I intended on upgrading around the begining of next year and while a 520W can easy handle what I have now and probably what I intend to upgrade to. With a fice year warranty on these things is it worth spending another 30quid to get the 620W and making it last for another upgrade afew years later? Or will the design of the 620W be outdated by then?
Another question is I want a fan for the front of my Antec Sonata II so I can turn the one on the back down abit and keep it quieter, what fan will fit in there?
Cheers
1st question
tbh the 620 is not gonna really be used now i mean i use 400w full load on my rig so itsa safe to get the 520 and should last 2-3 years unless you go really top end then the 620 would be needed
you could always go for the ocz psu and its cheaper than the 520w corsair
