I see you started another thread after this looking for a suitable PSU ekam and I'd say that 600W OCZ is good as well.
If there truly is no way of stopping them putting the PSU in, then I'd ask them for a written guarantee that it will be ok and won't damage your PC stating that any damage so caused by a faulty PSU they will be liable to incur the cost of repairing with suitable parts.
You will actually be protected as well by the Sale of Goods Act 1979 as well. Section 14(2) states that "Where the seller sells goods in the course of a business, there is an implied term that the goods supplied under the contract are of satisfactory quality". And if you have told him you intend to put a better quality graphics card in as well, then you are also covered by section 14(3)(a) which states "Where the seller sells goods in the course of a business and the buyer, exressly or by implication, makes know to the seller any particular purpose for which the goods are being bought, there is an implied term that the goods supplied under the contract are reasonable fit for that purpose...".
And if the PSU is ok, but there is a problem with your PC later on due to the way in which he has installed the PSU you will be protected by the Supply of Goods and Services Act 1982 under section 13 which states "In a contract for the supply of a service where the supplier is acting in the course of a business, there is an implied term that the supplier will carry out the service with reasonable care and skill." So if he damages any parts when installing it, he will have fallen below the level of reasonable care and skill and be liable for repairing/replacing said parts.
So, don't worry. The system has your back.
