PSU and Graphics Card Upgrade
5 Dec 2009
Scotland
Hi im about to buy a new PSU a long with a Grahpics card and im not really sure if its compatible with my motherboard.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-117-XF&groupid=701&catid=56&subcat=938
http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-CS&groupid=701&catid=123&subcat=
and this is my current pc specc: http://support.packardbell.com/uk/item/index.php?pn=PB34330401&g=1400
this is my current monitor: http://i35.tinypic.com/b8n68x.jpg
PS. im not a tech expert and i could some friendly suggestions :)
Having a look for the Cuba (MSI MS-7301) Motherboard support page on MSI is not easy!
From HP website:-
Form Factor
µATX Form Factor
24.4 x 24.4 cm
CPU Support
Intel Celeron D 3xx and 4xx models
Intel Pentium 4 5xx and 6xx models
Intel Pentium D 8xx and 9xx models
Intel Core 2 Duo models with LGA775
533 / 800 / 1066 MHz FSB
Chipset
VIA PT890 Northbridge
VIA VT8237A Southbridge
System Memory
DDR2 400 / DDR2 533 (2 banks)
Support for up to 3 GB system memory
Expansion Slots
1x PCI Express 16X
1x PCI Express 1X
2x PCI
Ethernet Controller
LAN 10/100 (VIA VT6103L)
FireWire (IEEE 1394) Controller
VIA VT6308 IEEE 1394 controller
Audio
High Definition Audio subsystem using the Realtek ALC 888 audio codec
IDE (HDD, ODD)
2 x SATA connectors
2 x Ultra ATA-133 connectors
It should work Okay. Can't see any problems; I would wait for a second opinion though. The 4850 will generate a fair amount of heat so i hope you case is well vented!
If you are not upgrading in the future you might be able to downgrade the PSU to a 450W for a few pennies. The 4850 will generate some heat so I hope your case is well ventilated!
Watch the links; refer to T+C. not a bad choice at all but it will cost £60 incl P+P from a dealer through amazon and can be easily beaten on price. For 60 I would expect the corsair 550 which is really really good.
Basically find a 450-500W PSU that looks good and check the reviews for it. If you can't find a review definately don't buy it! Apart from the antec basiq and the Akasa; they all look good (could always be proved wrong by a stellar review!) .
