PSU and other small questions
16 Jun 2012
Denmark
Hi guys!
I'm building a new Pc and i'm currently looking for a good psu.
Specs so far:
3750K (OC) - With Evo Fan
R7850 (OC) - Possible CF in the future
Corsair Vengeance 2x4 GB
Samsung 830 SSD
1TB HDD WD
ASRock Extreme 4 or perhaps the MSI-G45? or the UD3H?
Case P182 (Using from old rig) - Antec P182 Gun Metal Black 0.8mm cold rolled steel...
So, i'll will be running with an OC CPU and in the future possible 2x7850 thats overclocked. My case currently got 3 120mm fans with space for another one.
Also im curious about which mobo to get. I've pretty much narrowed it down to these:
MSI Z77-G45 - PCI Express 3.0 x16/0 or x8/x8
ASRock Z77 Extreme 4 - PCI Express 3.0 x16/0 or x8/x8
GIGABYTE GA-Z77X-UD3H - PCI Express 3.0 x16/x8
Listed in price order, cheapest first.
The MSI is 20$ cheaper than the ASRock.
The ASRock is 24$ cheaper than the GIGABYTE
Note that the prices are different where i live.
As for the PSU i've currently looked at the Antec HCG 620M: http://www.newegg.com/Product/Produc...82E16817371059
And the OCZ ZT 750: http://www.newegg.com/Product/Produc...tem=17-341-052
But some have problems with Ozc and others got some problems with cable length etc.
i would prefer a modular PSU since if i'm going xfire later i wont have those extra cables taken all the airflow. But if you can convince me to get a non modular then go a head :P
But ofc others will also do (:
Thanks
-Lazdaa
