1 Sep 2011 at 11:12 #1 Efour Efour Caporegime Joined 8 Sep 2005 Posts 30,753 Location Norrbotten, Sweden. got a corsair 650TX currently running 1x 2500k turbo clocked to 4.4ghz 1 x 6870 2 x samsung 1tb HDD 1 x 60gb SSD 1 x DVDRom 3 x 120mm fans 1 x 200mm fan i want to add another 6870 xfire would this be too much?
1 Sep 2011 at 11:53 #2 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 Your PSU should be powerful enough. See here. I believe your power supply only has 2 PCI-E power connectors and for Crossfired HD 6870's you need 4. You'll need to use molex to PCI-E power adapters for the other 2 connectors. These are usually supplied with the graphics card.
