- 12 Feb 2006
- Surrey
just had my psu blow up on my pc which couldn't have come at a worse time. I am probably going to have to replace it but before i do i want to make sure it isn't still in warrenty as i have seen some cheaper ones with 3 years warretny and this is just over 3 so hoping perhaps it has 4 years warrenty.
the psu is an enermax liberty elt620awt bought from ocuk. who do i contact to find out what warrenty it had?
if i buy another how can i find out what power will do? i know the 620w was way over what i needed as i planned to have it for future builds.
any chance a usb device being charge could have caused it to blow? a friend had plugged in their device and after an hour it blew up so seemed a little too coincidental to not be.
i'm looking at replacing it with this one if it's enough power for my system. how will i know if it will have the correct connections or are all the same?
thanks
thanks
