Alright, bought an, EVGA 750W PSU this morning. Everything is up and running but there was a hiccup.
Using all the same leads except for CPU and Mobo because my blown PSU was semi modular, with everything plugged in I got power to the NB and RAM but it wouldn't turn on. Had a flick through the book and it said about using the peripheral port for fans, pumps etc, so I plugged that in and nothing changed. Another look at the book said to not put the split connectors into the PSU which I did do for the GPU so I swapped that around and at the same time just decided to unplug GPU and Sata's from the PSU to see what would happen and it worked. So I plugged GPU back in, tested and it worked, put the SATA's back in and didn't work. So I changed PSU SATA cables to the new ones and redistributed the load to have 2 hard drives on one lead, so 2 HDD's share 1 cable and 2 SSD's share 1 cable, plugged it all back and everything worked.
Different PSU, different internals I suppose on how it delivers it's power. Not something I've experienced before. On my old PSU I had 2 SATA leads powering 4 HDD's and the fans, pumps, etc. I prefer how this EVGA PSU has it set up, makes it less of a cable jungle and easier to see where things are routed.
