PSU cable help needed
21 Jun 2016
Stonehaven
I have the Corsair SF750 PSU, which comes with 2 dual 8-pin pcie connectors for the graphics card. However, working within a mini-itx case (the NR200p), the fact they are dual connectors mean they are taking up a lot of room and don't look as good.
I am struggling to find single connection 8-pin PSU cables to replace these with. I see lots of extensions, but I need male to male.
I have found one, but it says it is for the ASUS G20 ROG PSU, and I am uncertain if I could use this with the Corsair SF750.
It would easy if I wasn't planning on a RTX 3080 which I need two separate PCI cables plugged into the PSU. But because of this, I end up with four connectors for the GPU which are hard to keep tidy / hide.
If your budget allows your best route would be custom replacement cables made to your specs by the likes of cablemod or pexon.
Amazing that after all my searching I never landed on that. Might be a bit long but I can hide most of that away. Many thanks.
I olooked at custom cables but the expense was a tad high. Also needed a minimum order which again rauised the cost.
Take a look at CORSAIR Premium Individually Sleeved PSU Cables Starter Kit think they have single pcie cables but you get the whole kit for £50
Remember to check.
