PSU cable long enough?
29 Apr 2003
London, Forest Gate
Going to order the Gigabyte SUPERB 460w Power Supply
BUT will the cable reach the graphics card using the following case / mobo / gfx
Akasa AK-ZEN-01-WH Rev.4 Zen White Case
AMD Athlon 64 X2 Dual Core 6000+ 3.00GHz (Socket AM2)
Gainward ATI Radeon HD 3870 XT 512MB GDDR3
Asus M3A AMD 770 (Socket AM2) PCI-Express DDR2 Motherboard
Will I be OK ? with this Gigabyte PSU , my budget is very tight and I shall be placing a order today (deadline)
can't see it beinga problem. From what I found on google the case has the power supply in the top.
I've only seen extension cables being used in either the really huge cases or the ones with the PSU in the bottom.
I actually used extension cables for both the MB power leads in my 1200 build
Thanks for the information, my problem is that I need to order all the items by end of play - today.
