PSU Cable missing
11 Apr 2007
I just upgraded my graphics card which requires 2pcie 6pin cables, but it appears I only have one. I'm pretty sure I didn't lose it! I think they didn't send me 2 the first time round and I didn't check as I only needed the one. It was 4 years ago but Corsair give you a tidy pouch to prevent these issues.. sigh.
So; its a corsair HX620w, after some digging I don't know too much still other than potentially going through their RMA service, which I can imagine would be potential weeks if they were kind enough to send me an additional cable?
I definitely can't use other branded PCIe cables though right? I have an old spare OCZ one from at least 6 years ago it must be, but, even as the pins line up, theres a chance they might have switched one of the cables internally to the psu?
Or am I screwed into buying a new PSU? Cheers anyone that can help.
Buy one of the braided corsair kits for the HX series ;)
Failing that, ask Corsair nicely if you can buy a replacement cable from them, odds are they will send you one free of charge :)
If you have a multimeter you might be able to sub one of your OCZ cables in if it's got the same physical connections. Swapping a few wires around would be simple enough. Could be risky though.
Hmm, don't have one but wouldn't risk it if a simpler solution exists.
What about this?
http://www.overclockers.co.uk/showproduct.php?prodid=CB-033-OK&groupid=1929&catid=153&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CB-018-AK&groupid=1929&catid=153&subcat=
2 4x pin plugs converts to 1 pcie 6pin
No issue with voltages there?
I thought most graphics cards came with PCIe to molex adapters anyway ?
Have you checked the box the graphics card came in ?
Yes, I got the VTX3d AMD 7950, it only came with crossfire link, hdmi/dvi, hdmi/minihdmi cable and one dvi/vga plug.
Do those adapters I link do the job then you reckon? Desperate not to damage anything ;)
Most GPUs do come with the adaptors, I actually got 2 with my 6950 which is strange considering you got none at all.
The adaptors will do fine.
