PSU cable question regarding ferrite rings
23 Nov 2009
North Leicestershire
is it safe to totally remove them on the corsair PSU's to braid the cables. they are only on the pci-e connectors and they look like ferrite rings wrapped in heatshrink???
If they are there they must be important. You can remove and fit elsewhere on the cable though. Never seen a ferrite on a pci express power cable before.
just googling apparently they are on all the HX and AX series psu's but only on the pci-e connectors
