PSU cables questions.
29 Nov 2011
So in my older build I have an AX760i and the new build a CX500M.
I've managed to lose the big pouch of cables that came with the AX760i and I don't know if I could do this so some please.
Pics
Can I use the 6+2 side but only use the 6 in the PSU and the 8 on the other side in the GPU?
I did read that even though it says those certain models only on the cable, it would be interchangeable providing it was the 760i
Apparently to a few forum posts they are compatible however I need to know if I could plug the 8pin into the 4x4 on the PSU and be fine, or the other way round and use the 6+2 on the PSU and normal 8 on the GPU.
Or could I use this
To connect my current 6 (+2) pin cable into the PSU acting as an adapter of sorts and use the 8 pin side in the GPU?
