PSU check
18 Oct 2002
Hi
would a Corsair TX850M be pushing it for this setup or ok?
i5 2500k @ 4.6
asus p8p67 pro b3
4 gig ddr3
2 x gtx 480
1 ssd
1 sata hd
dvdrw drive
gfx cards will be at stock only overclock is cpu.
Another thing to consider is that the system power may actually be power drawn from the wall and not the actual dc power the PSU is converting. I'm not sure how that site report their power draw. If it's wall power then a true 850w pay will draw 950-1050w from the wall at it's peak depending on it's efficiency and mains voltage.
Is there anything one could use to measure how effective a PSU is? Ideally software, but i have a multi-meter handy.
Power pulled from the socket is easy. But anything to see if your PSU is struggling with output?
Slight hijack (soz) thought it might help OP too tho
Guru3d definitely measure the power consumption at the wall.
Don't know about Anandtech tho.
