PSU choices
19 Jul 2006
I've narrowed down my PSU to one of three. They are the OCZ ModStream 520W, the Hiper Modular 580W and the Seasonic S12 500W. Which of these would you recommend to run the following rig:
Conroe E6600
Gigabyte GA_965P_DS3/4
2GB G. Skill NR PC2-6400
Seagate Barracuda 250GB
NEC ND3550
Floppy Drive
Sapphire Radeon X1900XT
Arctic Cooling Freezer 7 Pro
3 12cm Case Fans
As an aside, is the side fan in the Thermaltake Armour Jr case an 80cm, 92cm or 120cm fan?
Thanks in advance for any help.
Seasonic or OCZ.
Seasonic if you want silence, OCZ for modular and excelent tech support.
Go for the Seasonic, but for the fiver extra you can get a Tagan 580Watt Modular.., so more value for you money and very quiet and a great PSU...seems you have enough case fans to deal with the heat...so the Tagan would be the better choice.."Tagan TG580-U15 580W " and the modular cables are a dream...
Yes.
FYI the 'A List' of psu manufacturers i.e manufacturers whos psus are reliable, don't take out components when they die etc etc
Seasonic, Enermax, OCZ, Tagan, FSP, Antec.
Joe42 said:
Yes.
Yep, can't go wrong with any of them. Or PC Power & Cooling if you're feeling you wanna spend loaads of money.
