PSU connection to a GTX 4080
23 Dec 2014
Burgess Hill, West Sussex
Hi,
I have an Asus TUF Gaming 750W 80 Plus Gold Power Supply with a Zotac GTX 4080. Can I use the single high power PCI-E (12VHPWR) cable direct from the PSU or do I need to use the 3-way splitter and feed each PCI-E separately?
Thanks in advance
The adapter is provided because most PSUs don't have them, but if you do have the connector, then you can use it. Make sure it is fully/firmly seated.
