- 23 Mar 2011
Hi there!
I just got a new psu from here!
Just a straight replacement for old one, however 1 of the motherboard connections was a bit different!
The cable was 8 pin and the socket on the mobo was 4 with the remaining 4 blacked off with a little cover!
The 8 pinn cable did seem to split into two so i attached it where the old one was with the other 4 pins of the cable not connected!
The pc ran fine so im guessing this is ok?
Sorry if this post makes no sense! Hope someone knows what i mean, just want to be sure that this connection is ok!
Also a side note, how does one check cpu/gpu temps etc?
Thanks
Thanks
