PSU connections ( 2-4-6-8 ? )
18 Oct 2002
Behind you... Naked!
Just need some clarification...
There is often an extra 4-pin power connection thats present on some motherboards
There is on some others an 8-pin connection right?
Now, on my Abit QuadGT, I have bought a 4 Pin to 8 Pin adapter and its fine.
It was als operfectly fine before that when I just connected the 4-pin connector directly to it, and ignored the other 4 pins.
Thats fine.
Now, I have run out of PSUs that have the 4 or 8 pin connections to the motherboard, however... I do have a couple of PSUs that have 6 Pins.
Now, I have rammed this onto the back of a Graphics card and thats got that working, but can I use that 6 pin connection in an 8-pin socket on a Motherboard and only have 2 pins missing?
Are they the right pinouts? - 12v and GND for each pair ?
The plug fits... Soem are rounded and some are square, but it fits just fine.
No. don't you'll damage your motherboard, you're motherboar will be able to support 4 or 8 pins, but 4 + 2 would almost certainly do damage and the arrangement of cables are almost definately different even if the shapes fit.
Yes, thanks... I just come back to say that I have realised that the 12v and GND are reversed...
PHEW!
This Mobo does not have the 4 pin connection anyway, jus tthe 8 so I will just see if it will go on that... I dont see why not.
Many thanks for the Quick reply though mate...
the 8 pin will fit as long as there is no obstruction in the place where the extra 4 pin should go or you could just dremel it to seperate the cables into 4+4pin.
What? Eh? No, its fine.
I only wanted to know about whether I could use 6 pin but its either 4 or 8, so, job done.
And FYI if the 4 has been blocked off, its usually a cap that you can flick off.
I have currently got 5 Mobos that have the 8-pin socket and a couple had 4 pins blocked off but I simply flicked the cap off.
If you have to dremmel it then thats an even worse plan than mine was.
I only asked about the 6-pin job simply because I am having a play with some older stuff and I have run out of decent PSUs and I have dug into my spares.
Ah, I see what you mean... you mean about fitting an 8-pin into the 4 pin socket on the Mobo!!!??
No its ok, I know that 4 pin and 8 pin are interchangeable ( Yes, provoding the 8pin plug has room ) but I was looking at the 6 pin you see... Thanks for that.
Oh, and thanks... The PC is running now.
I think I will give it to my daughters friend, cos her mum's fit.
so is her dad but hey.... LOL
