PSU Connectors... confusion
23 Mar 2007
Kent, UK
I posted a while back asking what the prefered PSU was that was suitable for a QX6700 system with 8800 GTX and future expansion with an additional 8800 GTX in SLI mode.
I was told the Corsair 620W was the best to get for this.
I was about to place an order today however I noticed that this PSU only has 2 6 pin PCI Express connectors, but AFAIK doesn't the 8800 GTX require 2 connectors per card?
Is it just a case of using some adaptors, a mistake on the site I was looking at (a competitor) or should I be looking at a higher power rated PSU which definately has 4 6 pin PCI Express connectors?
RaiderX said:
it will handle the dual-GTX, you will just need to use the Molex to PCIe adaptors included in the box
That's what I was hoping, this PSU gets nothing but praise constantly on here so it's gotta be a good one to get! Thanks :)
