19 Dec 2012 at 19:41 #1 Casterina Casterina Associate Joined 17 Nov 2011 Posts 852 The current PSU have these connectors, 1x PCI-E 1x 4 pin CPU 1x 24 pin ATX 2x SATA 3x Molex It only has 2 SATA cable but I need another one as I will install 2 HDD and one Optical drive
19 Dec 2012 at 19:44 #2 OptimaLnrg OptimaLnrg Soldato Joined 9 Mar 2009 Posts 2,877 Location - you can get molex to sata adapters if that's what you're asking
19 Dec 2012 at 19:46 #3 Tealc Tealc Soldato Joined 13 Jul 2009 Posts 7,349 Location Llanelli Something like this? http://www.overclockers.co.uk/showproduct.php?prodid=CB-008-CT or this http://www.overclockers.co.uk/showproduct.php?prodid=CB-037-OK or this http://www.overclockers.co.uk/showproduct.php?prodid=CB-084-AK There's loads of them..
19 Dec 2012 at 19:52 #4 Casterina Casterina Associate OP Joined 17 Nov 2011 Posts 852 So a Molex to SATA will do the job fine?
19 Dec 2012 at 20:00 #5 setter setter Caporegime Joined 14 Dec 2005 Posts 28,067 Location armoy, n. ireland Yep, i use molex - sata adapters on my setup. Just because of the stupid way in which corsair have the connectors on the cable.
