PSU Dead
3 Mar 2008
Psu just gave up the ghost. Time to get a new one, but I not sure how many watts to get.
I'm running a p8p67 with a
i5 Sandybridge at 4.6
4 hard drives and
ATI 6950
Would a 850w be overkill? Can anyone recommend a decent psu at a good price
From OC - Antec, Cosair, BeQuiet & XFX are the brands I'd recommend.
Any Seasonic which are rebranded buy some of the above.
Remembering they do have a range from budget to very high end, you tend to get what you pay for.
What's your budget?
Ok here's a range. :)
XFX Pro range, all Seasonic consider 750/850 if you think you may want to use crossfire/sli in the furture.
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=123&subid=1497&sortby=priceAsc
BeQuiet Efficient Power 600W
http://www.overclockers.co.uk/showproduct.php?prodid=CA-051-BQ&
Corsair Enthusiast Series TX 650W V2
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-CS&groupid=701&
Corsair Enthusiast Series TX 750W V2 (Modular version below)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-038-CS&groupid=701&
http://www.overclockers.co.uk/showproduct.php?prodid=CA-047-CS&groupid=701&
Corsair HX 650W ATX Modular SLI (was their flagship range until the AX series came out)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-022-CS&
If you just stick with one card the XFX 650 and the TX 650W V2 are good options.
