When a PSU has dual 12V rails, does it automatically use both or are different connectors connected to the different rails?
Thanks for the reply, so it really doesn't matter which molex/PCIe connection I use for the videocard which is good.Mole said:The split is between the motherboard 12V connector (4 pin one) and the rest, as far as I am aware. It is done to give supposedly 'cleaner' power to the motherboard and hence the CPU.
Everything else (PCIe, molex, etc. are on one rail). Worse case scenario is that if one rail is overloaded the PSU might automatically switch to combined mode and act like a classic PSU.
Martin
