PSU Extension Cables
2 Jun 2013
Glasgow
Hi,
I am finishing my friends build and I have noticed all his PSU cables can be re-routed round the back of the case and still fit into the slots nicely except for the 4+4pin CPU Power cable.
I was looking on eBay for extension cables and I need someone to confirm this is the correct item:
*** No competitor links please *** - Will Gill
I was also thinking about getting extensions for the PCI-e GPU as I could reroute them better too. Is the correct cables for them just "6+2 pin extensions"?
Thanks
Yes if I flipped the PSU (facing down) then it might reach but it looks quite ugly like that with all the manufacture details along the side.
Sorry for that..
Am I right in saying a 8 pin extension that would be used for the CPU Power can also be used for 8 pin PCIe into my XFX R9 280X (and then just buy a 6 pin for the second slot)?
I have basically ordered:
2 x 8 Pin Extension (1 for CPU power and 1 for GPU)
1 x 6 Pin Extension (for the other part in the GPU)
Thanks for your help again guys :)
Damn!
I just spoke to the seller and apparently the 8 Pin extension I bought only works for the GPU card and they said I need a 8 Pin ATX CPU extension instead for the CPU Power
So I actually needed: 1 x 8 Pin ATX CPU Extension, 1 x 8 Pin PCIe Extension and 1 x 6 Pin PCIe Extension...
They looked so alike on the website aswell. Problem sorted anyway.
