Hey everyone. I recently finished building a system with a OCZ ModXStream Pro 500W PSU but I've found the fan on it seems to run at full speed the whole time. It can't be a heat issue because my idle temps are 25c for motherboard, 31c for CPU with stock cooler and 26c for overclocked HD 7850. I've looked in the BIOS but there aren't any settings other than for case and CPU fans, which are fine. My motherboard is an ASUS P8H61-MX USB3 and I'm thinking it may have something to do with it somehow overriding the PSUs own fan sensor. There is a BIOS update but do you think that could make a difference (it doesn't mention PSU fans in the description and I really don't want to mess up the system)? Any other ideas about a solution or cause? I don't think the PSU is faulty in any way because the one I swapped it for was doing something similar, which I thought was only because it was poor quality.
