PSU Fan Cables - Where To Connect?
30 Aug 2014
Found this PSU the other day... detached fan cables and left to throw away:
Anyone know where to solder the wires to? Was gonna see if I can fix it. Cheers.
Yeah don't.
When I was younger I had a nasty encounter with a PSU, thinking I was all that. It was even unplugged, if you're not sure what you are doing, don't do anything.
You see that lite white JST PH 2 pin header connector. I bet that'll be the spot for the fan. It's also close to the voltage output rails which would make sense.
You need to solder to the underside of the board unless you can find the traces for the header. It might not be a regulated fan output so may run at full pelt.
