25 Jul 2011 at 20:48 #1 Dicehunter Dicehunter Soldato Joined 19 Feb 2007 Posts 15,509 Location Northampton Which way should i have my psu fan facing, up or down ?
25 Jul 2011 at 20:48 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Down if its the case in your sig.
25 Jul 2011 at 20:48 #3 Moothead2 Moothead2 Soldato Joined 23 May 2011 Posts 10,501 Either, but down is usually prefered.
25 Jul 2011 at 20:49 #4 RJC RJC Don Joined 29 May 2005 Posts 29,094 Location Kent Depends on the case, does it have grills to allow the psu to pull fresh air in?
25 Jul 2011 at 20:49 #5 Dicehunter Dicehunter Soldato OP Joined 19 Feb 2007 Posts 15,509 Location Northampton RJC said: Depends on the case, does it have grills to allow the psu to pull fresh air in? Click to expand... sure does
25 Jul 2011 at 20:51 #6 RJC RJC Don Joined 29 May 2005 Posts 29,094 Location Kent DF1986 said: sure does Click to expand... I would placed the psu down so it pulls fresh air in.
25 Jul 2011 at 20:52 #7 Dicehunter Dicehunter Soldato OP Joined 19 Feb 2007 Posts 15,509 Location Northampton Thanks for the info peeps
