So Just recently my PSU fan has started making a noise when it reaches High speeds (I think the bearing has worn out) it's not constant but I'm assuming it will get worse down the line. And was hoping to get some advice from you guys.
It is a "Powercool PC750"
My PC has a 3 year warrenty from the people who built it for me do you think they would replace the fan/powersupply?
Should I just go out and get a new fan? (I assume its a 200m fan?)
Or Should I just go and get a new PSU any good ones for around £50-£80?
Thanks for the help.
