Hey, i was just wondering if anyone has tried rerouting the fans from their PSU to their CPU or system fan headers, my PSU is 1kw and im only using about half that so the air coming out of the back was always cold but even then it insisted on running the fans at 1500 rpm, i tried putting resistors onto the fans to slow them down, which worked on the 80mm, but when i tried on the 140mm the PSU low fan speed warning buzzer kicked in, and even though it ran fine it was very loud and annoying, i tried finding the buzzer to remove it, but i think its buried deep inside the bundles of cables in the PSU somewhere so i gave in and just decided to solder the fans together and extend the cable to the Mobo headers.
I intend to set up the the fan speeds to increase when the CPU temp rises, as the PC will be under load and extra cooling on the PSU will proberbly be required. Could anyone suggest the best way of doing this plz? Atm i just have the CPU header set to voltage and speed to silent which i set in the bios, as they are 3 pin fans from the the PSU i figured that was best, but i dont know if this will speed up my fans automatically, or if i need a program so manually set the temp lvls required to speed up the fans.
I've always just used a fan controllower and havent had an air cooled system in over 10 years so i dont know much about setting up fan speeds and stuff, i normally just twirl a knob on the front of my PC if i want more cooling
Cheers for any help.
