- 6 Dec 2008
Okay so I bought a brand new CS650M Corsair PSU, along with a new graphics card, I decided to plug in the PSU first without the new GPU and thank god I did....
After I plugged in the new PSU, the system booted for literally 3 seconds, if that... and then turned off. There is no noises/beeps, nothing just normal startup, but then instant shutdown after 3 seconds. I unplugged all non-essential things and tried again... same result.
So I put everything back in and put back in my old PSU, and turnt it on, my CD burner pumped out smoke... I shut it all down and disconnected all non-essential things again... turned it back on, with my old PSU still and it all ran fine... no issues for the last hour. I plugged my other stuff in, graphics card, additional fans e.t.c and still fine no issues.
I feel that the PSU I bought was faulty and it caused something to snap inside the burner which then burnt out when I put my old/working PSU back in. Am I wrong? could there be something else at fault here? Keeping in mind my system is fine on this old PSU, just not the new one I bought... what should I do? is there a safe way to find out if the PSU is at fault? I did see that trick with the paper clip but that seems a little dangerous lol.
