12 Jul 2014 at 14:32 #1 Mooeyman Mooeyman Associate Joined 30 Jan 2012 Posts 21 Location Herefordshire Hi all, not sure if im posting this in the right place. Friend of mine wants to get the Gigabyte 760 on offer at OC but has a 500w psu. Would a Corsair CX600 Builder Series 600W be ok to run it? Many Thx.
12 Jul 2014 at 14:35 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent What is the current model of the PSU he is using and spec of the system. Generally a 500w PSU would be OK.
12 Jul 2014 at 14:39 #3 Mooeyman Mooeyman Associate OP Joined 30 Jan 2012 Posts 21 Location Herefordshire I dont believe its a branded one, also i asked the peeps who built the systems and they said he'd need to upgrade the psu.
12 Jul 2014 at 14:43 #4 Mooeyman Mooeyman Associate OP Joined 30 Jan 2012 Posts 21 Location Herefordshire I dont believe its a branded one, also i asked the peeps who built the systems and they said he'd need to upgrade the psu. The system i believe is AMD GB 6300 3.5Ghz 500gb HD, 4gb Ram, Nvidia 640gt 2gb.
12 Jul 2014 at 14:45 #5 Idleman Idleman Soldato Joined 14 Apr 2011 Posts 12,269 Location Newark Pop the side of the case off and have a look.
12 Jul 2014 at 14:52 #6 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent If the PSU is a no name cheap brand then have a look at the PSU below: http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-SF
12 Jul 2014 at 14:53 #7 wellibob wellibob Soldato Joined 27 Mar 2006 Posts 4,055 RJC said: If the PSU is a no name cheap brand then have a look at the PSU below: http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-SF Click to expand... What he said. Not the cheapest but currently the best psu's you can get atm.
12 Jul 2014 at 15:10 #8 Mooeyman Mooeyman Associate OP Joined 30 Jan 2012 Posts 21 Location Herefordshire and it wud be fine for the gigabyte 760?
12 Jul 2014 at 15:12 #9 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Mooeyman said: and it wud be fine for the gigabyte 760? Click to expand... Ample. You probably looking at 200w at full load.
12 Jul 2014 at 15:34 #10 Mooeyman Mooeyman Associate OP Joined 30 Jan 2012 Posts 21 Location Herefordshire Great, Thx very much for all ur comments.
12 Jul 2014 at 20:51 #11 Sasahara Sasahara Soldato Joined 12 Feb 2009 Posts 4,421 http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-EA At £41.99, the cheapest I'd recommend. Certainly good enough for that system and a GTX 760, I've brought two for higher power usage systems.
