PSU for 8800GTX?
20 Oct 2002
North West
At the moment I have an antec 480, would this power a GTX? I am hopefully finishing uni in April and may get myself a finishing gift :p.
System is:
DS3
E6300@3ghz
2*512mb ram
2*320gb sata
1*160gb drive
1*DVDRW
Audigy 2
I would look to upgrade your PSU as a must.
Minimum I would be looking at with your rig would be 600 Watts.
Matt
Well in January I'll update my 480 to an 800 Tagan and get another 1gb of ram instead of two. I'm leaving vista for a while until compatability's sorted.
System is:
DS3
E6300@3ghz
2*512mb ram
2*320gb sata
1*160gb drive
1*DVDRW
Audigy 2
It should be fine, you don't need to upgrade your PSU.
I have no problems with a similar rig and an Enermax 500w (32A/384w combined). The psu doesn't get hot, and the fan speed stays low.
deleted said:
personally i'd invest in the RAM your after before PSU
That's being upgraded anyway - when I moved from my 64 3700/2gb geil I could only afford 1gb of the new geil as it was £90. I'll be picking another gig up before jan.
Matt
that's a bit melodramatic, i'd say 450-500w would do you fine.
quality and amperage is more important than wattage 99% of the time.
Just thinking ahead of the next upgrade!
Matt
