PSU for a Lian li v800
23 Nov 2004
UK
Just put together a new pc using the v800. The space for the psu is quite tight and wondered if anyone had any thoughts on a suitable psu?
According to another website the PSU area is 151 x 87 x 160 (W,H,D). Corsair HX620 is 15cm in depth and rather highly regarded, plus it's modular, any square looking PSU should do really
Brilliant,wasn't sure if it would fit. Thanks for the reply.
They are that quiet, that when i shorted the black and green cables to turn it on to test (without it being connected to anything) i thought it wasn't working, i had to physically look at the fan to make sure it was on. Even on full load, i haven't seen the fan spin up any more, or at least not audibly. Fantastic PSU's imo.
If it's an HTPC though, i would assume you dont have a huge power requirement and the HX520w would most likely be enough for you. (will need specs to make sure though...)
