PSU for a MSI PRO Z690-A DDR4 ?
21 Oct 2002
30 miles north of London
Just upgrading my old system to a Intel 12700K + MSI PRO Z690-A DDR4 and noticed that the Motherboard has two CPU_PWR connectors.
My existing PSU (Coolermaster SilentPro 600W) has only got 1 x 8 pin CPU power connector, will this be enough or is it time for another PSU ?
Running 1 EPS connector should be fine. Connect it to the first connector which on my Tomahawk is the left-hand one, check its the same on your Pro. You'll only really need the 2 EPS connectors if you are extreme overclocking.
I connected both on my mobo just because my PSU had 2x EPS connectors so thought I may as well.
Thanks for that, got it all connected & it seems to be fine (so far ;) )
Even though it's currently working, I'd definitely look to upgrade that PSU soonish, it's only an 80 plus white and is only 480W where it counts (on the 12V rail).
