PSU for Bitfenix Prodigy
28 May 2012
Can anyone recommend a good PSU for this case. From what ive been reading there isn't a whole lot of space for a PSU some saying 140mm is a good size. any recommendations for a 650-750W PSU that will fit nicely ?
I have a 160mm one to go in mine.. it /should/ fit as it has 180mm of space so 20mm for the extra cables should be ok
Right cheers for the replys, anyone know if you can fit a fan controller in if your running a h100 not sure how much room uve got exactly left.
I was actually reffering to the number of PCI slots used lol. Seeing as how the 7990 is a dual card does it not need 2 x 16 PCI-E lanes or is still a single lane card?
Lol guys I plan to put in the official AMD Radeon 7990 that, as I understand it, requires only 2 slots :)
So....
What aboot recommending me a decent 850w Modular PSU please?
:D
As long as it's 160mm max, it'll fit. The usual options are Corsair AX750, AX850, AX760, AX860, Seasonic equivalents.
Dunno about the card fitting the prodigy. Some cards take up two PCIE slots but are actually 2.5 / 3 slot high with a big heatsink eating up the space.
