PSU for dual GPU configuration
14 Jan 2007
I was wondering whether this power supply unit would be suitable for running a dual GPU setup with 2x NVidia 8800GTX graphics cards.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-CS
It has 3 x +12v rails all at 18A - some sources say this should be enough, but then other places I've looked recommend anything up to a 1000w PSU and this one is only 620w.
It's not so pressing at the moment since I will only be running a single 8800 for probably 6 months or so, but I am looking to get the second one when they become slightly cheaper. I will also be upgrading to an Intel quad core processor at some point aswell, when they don't cost £500 each, in the meantime it's going to be a Dual Core Pentium D 930 3.0Ghz. Do you think that this 620w PSU would be able to handle all of that?
Thanks for your help!
