PSU for i7-2600K - do I need an upgrade?
25 Jul 2003
ar y mynydd
Hi,
I currently have a 500W Tagan PSU. Am planning an upgrade with:
Intel Core i7-2600K
Asus P8Z68-V PRO Intel Z68
Corsair Vengeance 8GB
Also I have a ATI 5850 and a Asus HDAV 1.3 card.
Is my existing PSU going to be sufficient?
ta.
Depends on the 12V amperage. What does it says on the side of the PSU?
With that kit, I'd get something more adequate. Again the Antec 620W comes highly recommended while stocks lasts (£50). 750W / 850W PSU (XFX, Antec or Corsairs) if you want SLI ready.
for an i7 920 and an ATI 5850 anandtech got a power draw for the entire computer of 350W, so your current PSU is just fine
*edit*
just noticed the HDAV card. no idea of the power consumption of that. depending on how much tat uses, you might want to get the antec that oliver recommended
Well, the PC doesn't start straight away when I press the power on; the fans spin up and shut down twice, then the third go it boots as normal.
Last night got a BSOD (Kernel data in page) and my SSD wasn't recognised in the BIOS till I powered down.
New PSU time?
PSUs in order of budget
Corsair HX 650W ATX Modular SLI Compliant Power Supply (CMPSU-650HXUK) £103.99
Corsair Enthusiast Series TX 750W V2 High Performance Power Supply (CMPSU-750TXV2UK) £92.99
PC Power and Cooling Silencer 760W Power Supply £82.99
XFX 650W XXX Edition Modular Power Supply £78.98
XFX Pro 650W Core Edition Power Supply £61.98
Only the XFX 650 XXX and the posh HX650 are modular.
review of the 650 Core (the cheapest).
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=216
EDIT : I suppose the 550W will be enough. The Antec 620W, while gone up in price, is still competitive, but the XFX 650W is on offer and a better buy imo, for £2.
All these PSUs have been well reviewed by trusted sources. So you can look it up and see for yourself.
Only the XFX 650 XXX is modular.
Hehe, just got the 650w XXX edition myself instead of the 750w Pro for around the same price as I wanted modular :). It's the only thing I need before I can get building so feel free to urge it to come quicker :D.
