PSU For new build (e6400+x1900xt)
17 Oct 2002
I'm looking at the different PSUs and am getting more confused about which one to get. :)
New Build:
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail (CP-127-IN)
G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
Connect3D ATI Radeon X1900 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-CO)
LG GSA-H10NBAL 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-045-LG)
Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE)
not sure what I would need :confused: I have been looking at the 460w/500w ones atm, but not sure if that's a bit overkill?
was looking at:
Akasa Ultra Quiet 460W Paxpower Active PFC ATX2.0 PSU - Black Nickel with Blue LED Fan (CA-004-AK)
Akasa AK-P050FG8-BKUK 500W Green Power 80+ (CA-019-AK)
Hiper HPU-4K580-MK Type R 580W Modular ATX2.2 PSU - Black UV (CA-005-HP)
Tagan TG480-U01 480W ATX2.0 SLi Compliant Silent PSU (CA-000-TG)
So many choices :)
Tagan would be my choice out of those, not that the others won't do a good job but I'd rate it as the best of the selection. If you want to free up a bit more cash you might also look at the Geil PC6400 on This Week Only although it will be changing at some point today(if it hasn't already).
Seasonic s-12 500w would be perfect. Not modular though. Go for the m-12 if you have the cash.
The OCZ ModStream 520w ATX2.2 Power Supply (CA-017-OC) is pretty good aswell.
Tbh all the tagan, seasonic, fsp, enermax, ocz are good. Just choose one you like and is in your budget. I would go for at least 500w though, to future proof it if nothing else.
I think the Tagan looks about the best for the price :) as long as it's good enough for the system.
Spec comes to £900 :eek: not added a monitor yet either.
CP-127-IN Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail (CP-127-IN)
£139.99 £139.99
MB-152-AS Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
£129.99 £129.99
MY-013-GS G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
£164.99 £164.99
GX-053-CO Connect3D ATI Radeon X1900 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-CO)
£139.99 £139.99
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£11.99 £11.99
CD-078-SA Samsung SH-S182D 18x18 DVD±RW ReWriter (Black) (CD-078-SA)
£16.95 £16.95
CA-038-LL Lian-Li PC-7 PLUS Silver Aluminium Midi-Tower Case (No PSU) (CA-038-LL)
£47.95 £47.95
CA-000-TG Tagan TG480-U01 480W ATX2.0 SLi Compliant Silent PSU (CA-000-TG)
£51.99 £51.99
HD-078-SE Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
£62.95 £62.95
Subtotal £766.79
VAT £134.19
Total £900.98
Looking good.
Are you going to be overclocking? I would be tempted to go for the e6300, you would save some cash and it clocks very well.
I would also swap the ram for the geil ultra 6400.
Yep, forget the E6400 and spend the money elsewhere. My E6300 is at 3.5ghz atm :D
I seriously reccomend the corsair HX 520W PUS. I love mine, has x3 12V rails, very quiet, and just all round sexyness :p
