it certinally will, aim for a gold rated unit and you wont go far wrong, i have a corair sf 750w sfx powering a 3900x and a zotac 2080ti and have no issues, i'm however running the gpu stock and have a small oc of 4.1ghz on all cores on my 3900x, for the future you shoould be fine as next gen cards are likley to be built on 7nm tech (amd is on 7nm), if this makes it to the market it should further reduce power needed which is a win
