Psu for sff build
28 Sep 2022
Essex
Hi
I'm planning on building a pc within a custom case. Power draw will be 300 to 350 watts. Because of the confined space only something like a Pico type psu would fit. Can anyone advise/recommend a suitable power brick for the build. ie volts and amps.
Hi
You need to give us your budget and the build specs.
You’re asking for advice and giving us vague information. Be specific.
That kind of power draw is pretty high for a Pico PSU, they usually only go up to about 150.
You'd need something like this, I would think:
There's an SFF sub-forum that this thread might be better placed.
Just to be clear, with that kind of power draw would a 330watt power brick be adequate coupled with the hdplex?
