PSU For SLI
1 Aug 2011
Bristol.
Hello there, I was wondering if a 650Watt Antec power supply can run two of these -MSI GeForce GTX 670 OC Twin Frozr Power Edition 2048MB GDDR5 PCI-Express Graphics Card in SLI.
you should be able to use a 650w that i'm assuming you already own for this, although the psu's listed above will provide you with more headroom for expansion
It should be fine. I ran a 3770k at 4.5ghz and sli 670's. Total system power draw at the wall (incl momitor) was 430w in games.
Efficiency of more modern cpu's/gpu's is incredibly good. Previously i ran an i7 920 @4.2ghz along with sli'd gtx 470's overclocked to 750mhz. That system was showing a power draw of 630w in games. Furmark on extreme burn was 744w.
Indeed, I had the 480 and the i7 920 and got 630w from the mains, it surprising how small of a PSU is needed when looking at certain gpu's.
