- 8 Jan 2011
- London, UK
Hi all, I was wondering if you could just sanity check my PSU selection for the following configuration. I have a BeQuiet 1000W PSU Dark Power 12, the PC build is for a watercooled system, not yet built:
CPU: Intel 11900K OCed at 5.1/5.2ghz
GPU: NVidia 3080 EVGA XC3 ultra, mild OC
Drives: 3 x m.2, 4 x ssd
2 x D5 pumps
14-16 120mm fans
Depending on which online configurator I use, I get a range of recommendations from 750-1200W. I was wondering if there are any views here on this? I had understood 750 would be recommended, so went 1000w for some leeway.
Much appreciated
2 x D5 pumps
14-16 120mm fans
Much appreciated
