PSU Good Enough
axe
axe
Suspended
1 May 2006
Im Building the following
Pressler 3.0ghz
Asrock Mobo
2GB ram
X850xt
200gb hdd
Now i have ran out of money would one of the psu's which come with the cases be able to power this until i can afford a decent psu?
The psu in the case is a Winpower 450W PSU
Yes, thast should do it, but it may not have a PCI-E graphic card connecter.
I would suggest finding out if it does, if it doesn't, just wait until you have enough cash for a decent PSU
Wont need more than 450W anyway
It will be fine. If it doesn't have a PCI connecter...
Akasa PCI Express 6 Pin to 4 Pin Power cable adaptor for PCI-E Graphics Cards (CB-018-AK)
Allows you too use PCI-Express graphics cards with a 6 pin connector with older Power Supplies that only have 4 pin molex connectors.
Price: £2.95 (£3.47 Including VAT at 17.5%)
Two things to be aware of.
1: You can't measure the power in total watts, you need to look at the wattage of the 12v rail to get an idea of the power.
2: Cheap psu's have a tendancy to do damage to things connected to them when or if they die. They are usually ok for basic low spec machines but for a gaming machine they aren't particularly suitable.
I would swap 1gb of ram for a better psu myself.
