Hi guys. Apologies if this is in the wrong section. It kind of relates to two components so i thought it was best in the general.
I currently have a 1070 GTX FE which is a 8 pin PCI-E Connection. I have side graded to a 980TI which has two x 8 pin PCI-E Connections.
My PSU is the silverstone SFS Series 600W Power Supply housed in a Corsair 240 ATX Case.
There are no more PCI-E Slots on the PSU it self so i cannot connect another cable. How can i make this work so i can use my new Graphics card with this PSU please?
On the PSU box it says "Supports DUAL PCIE-E 8/6 Pin Connectors"
I hope i dont have to buy a new PSU, if i do, which would you recommend to fit in this tiny case? Hopefully it wont come to that. Would love your help please. Thank you in advance!
