PSU gremlins
16 Apr 2012
i bought a Seasonic 750w(model SS-750HT) 3 or 4 months ago and its starting to act weird.
Yesterday i started my computer like normal and i hear a fan go full speed, after further inspection it was the PSU.
All temps were normal and the psu wasnt warm at all...so i decided to do my full cleanup hoping it was just dust blocking something.
The big cleanup didnt change anything so i decided to check the power supply more closely...
No dust inside but i still used canned air in it just in case.
Started the pc, after around 20 mins the fan went quiet...checked if it was still spinning and it was running fine.
After around an hour i shut my computer down and went outside.
I came back 20 mins ago and it started doing it again.
If you can I think you should return it as I suspect it is faulty.The last thing you want is for it to blow and take other components with it.
