Hello
Last night at around 3am, I was woken up when i suddenly heard and saw my computer power up and then switch itself off a few seconds later. I was rather confused by this as it had been properly shut down the night before. I got up and turned off the wall outlet to prevent it doing this again for the rest of the night.
This morning, I turn the power outlet swicth back on and press the pc on button, it fails to turn on.
I can hear and extremely high pitch constant sound coming from the PSU and when i switch the psu off, the constant sound changes in frequency as it looses power and then is not heard. as soon asi turn the psu back on however, the noise returns.
I tried removing the main power plug from the mobo and using the paperclip trcik connected to a green and any black socket on that plug to see if the PSU would hop into action whcih it won;t.
Any ideas?
Is the psu dead? How do you think this could ahve been caused? and what PSU would you reccomend to replace it?
the system is :
Asus P5W DH Deluxe
Intel Q6600 at stock.
WD Raptor X 150gb
WD 500gb drive
4gb OCZ ram.
Corsair Hiper modular 530w
watercooling loop
ati x700 pro gpu
asus ati eah3650 gpu
The system is being upgraded shortly in the new year anyway so if the psu does need upgrading, it will need to support an i7 950
Please give me any replies asap so if needed i can order a new psu for delivery tommorow.
Thanks
Neil
Any ideas?
the system is :
Asus P5W DH Deluxe
WD Raptor X 150gb
WD 500gb drive
4gb OCZ ram.
watercooling loop
ati x700 pro gpu
Thanks
Neil
