PSU help!
25 Jul 2006
Been offered too much money for my current system to say no, so I'm basically selling it and upgrading to Conroe earlier than I thought.
So I should be buying...
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN)
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
Going to be getting a Scythe Ninja at a latter date and a X1800XT. But I need to try and get a case and a PSU to power everything and try and stay on budget.
So I have around £40ish, maybe more if it's really needed, but I've been told I need to make sure the rails can handle it, but I have no idea what I should be looking for.
So any help would be appreciated.
Cheers guy. :)
Well, as I have told you already, the cheap PSU I gave to you is only 17a on the 12v rail and has no over-voltage/under-current protection despite it being a 600w PSU, so that is a no-go and would probably explode if it came in contact with that Core 2 Duo setup and an X1800XT. Especially since it killed one of my hard disks last year.
I think that the Antec case with 400w should work as it has 25a on the 12v rails, and my current PSU has 29a on the 12v rails, but that case + PSU is £64. To be on the safe side I still recommend that FSP Sparkle 400w @ £32 as it has 36a on the 12v rails, and a cheap case to go with it.
The Antec case you just asked me about, with the 380w PSU, also has 25a on the 12v rail so it should suffice... Should. :p
You're useless :p you'll make me bankrupt one day.
Anyway, what about the:
Antec NSK4400 Mini Tower Case - 380W SmartPower PSU (CA-052-AN)
Bit less expensive and closer to my budget.
Unless I can save money on the RAM mentioned above maybe.
:cool:
Aye that PSU is just as good as the 400w one in the other case, despite having less total peak watts. I would like a second opinion before I say "buy it" but I think it will do the job.
