PSU HELP
firstly can i say you are spending a ridiculous amount of money there, you can get very similar performance for a lot less especially if you are willing to overclock.
changes i will make .
drop the qx9650 for the q6600 or q9450 and overclock it, this will save you at least £300
unless you need all of the features on the 790i based MB ,get one that use DDR2 ram and get ddr2 ram ,this will give you a saving of around £100 even if you get a 2x2GB pc2-8000 kit.
unless you already have 2x8800GTX, get only one and use the money you save towards your upgrade in the GPU department later.
add a good CPU cooler ,unless you already have one. i like the tuniq tower.
for the PSU,
http://www.overclockers.co.uk/showproduct.php?prodid=CA-146-CM&groupid=701&catid=123&subcat=1103
http://www.overclockers.co.uk/showproduct.php?prodid=CA-011-SK&groupid=701&catid=123&subcat=1090
http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-SK&groupid=701&catid=123&subcat=1090
http://www.overclockers.co.uk/showproduct.php?prodid=CA-147-CM&groupid=701&catid=123&subcat=1103
are a few suitable candidates, that i think will power your pc, most only has 2 8pin connectors though as far as im aware. http://www.overclockers.co.uk/showproduct.php?prodid=CA-011-SK&groupid=701&catid=123&subcat=1090 apparantly has 4 8pin connectors
