PSU help??
2 Feb 2012
Just wondering what wattage PSU i would need for this build?
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle
Intel 520 Series 240GB 2.5" SATA-3 Solid State Hard Drive - Retail
EVGA GeForce GTX 460 Superclocked *** 1024MB GDDR5 PCI-Express Graphics Card
Asus PA238Q 23" Professional ProArt Widescreen P-IPS LCD Monitor
and obviously a cheap optical drive
I was thinking Corsair AX650 and could upgrade again later on if i go SLI or Ivybridge or should i go AX1200 and will never need to upgrade unless it breaks?
Cheers
An AX650W is a good choice for that system - as it is very efficient, fully modular, extremely good quality, long warranty and will happily run two GTX 460 cards in SLI.
Though you may want to consider going for the AX750 - just so you can be assured it will run any future single GPU card with room to spare.
Though I wouldn't go as high as a AX1200 unless you really plan to make use of it. Not only is it very expensive, but at low PSU load levels (pretty much any load level with the current rig) the efficiency won't be nearly as good as a smaller unit - due to the PSU efficiency peaking at 50-60% total capacity (and falling off quite a bit at low load).
Some people forget how much power a system can draw whilst in use, and some use Triple or quad gpus and and multiple CPU'S.
My system in my sig pulls around 430w at full load ~
Why do people go with 1000/1200W so? Is it when running quad 580's that you would need it??
More or less yes, lots of gpus and massive overclocks etc.. I'm running an i7 920 @ 4Ghz with 12GB RAM and HD6570 on a 300w SFF psu in a low profile HTPC rig.. hasn't blown up yet in over a year :D
1 x MSI HD 6970 2048MB Twin Frozr III GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game £279.95
1 x MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card with FREE MAFIA 2 PC Game £259.99
1 x Corsair Professional Series AX1200 High Performance 1200W Modular '80 Plus Gold' Power Supply (CMPSU-1200AXUK) £244.99
1 x MSI GeForce GTX 560Ti OC Twin FrozR II 2048MB GDDR5 PCI-Express Graphics Card £239.99
1 x EVGA GeForce GTX 460 Superclocked 1024MB GDDR5 PCI-Express Graphics Card £127.99
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £119.99
1 x Corsair Professional Series AX650 High Performance 650W Modular '80 Plus Gold' Power Supply (CP-9020006-UK) £119.99
All good choices. However if you were tempted to spend around £245 on an AX 1250, then maybe you could consider spending that extra on your Graphics card. This would give you a better performance bang for your buck if you are gaming.
Check out the Video Cards Links and the anandtech comparisons links and choose whatever you feel most comfortable with.
lets hope u didnt curse your self with that comment :p
Nah worked out the psu requirements at worst case is 270w (it only has an SSD and BD-ROM and the 12v rail on the psu exceeded the max draw of the components. Always on 1.3v as theres no offset option but speedstep does clock it down to 1.6Ghz, its a decent Seasonic 300w so theres no danger :)
