I wouldn't touch any of the psu's that cost less than the HX550 in the 500-800w range on here. However, in the "up to 500w" range there is the XFX XT500 which should have more than enough power for a system with a 1050 in it. It's a Seasonic designed unit but built by a third party chinese builder for XFX. It has a single 12v rail of 460w and a 3 year warranty. It's not brilliant (you are not going to get anywhere near brilliant with your budget) but it will do the job. If you want anything better then you will have to significantly increase the budget.
Can you please state the rest of your components and if there is any overclocking just to confirm it's enough power?
